Hi All,
I finally managed to free my newly installed timing chain on a gen 1 , 500 engine.
I loosened the cam towers. Then removed the rockers. I then bolted the camshaft and removed the camshaft sprocket. Then installed chain on the camshaft sprocket and refitted sprocket/chain to camshaft. Then aligned the left bank(us driver side) , aligned the right bank and achieved a zero position on flywheel.Also see distributor position.
Now everything turns perfect and i have done this 5 times.
Question: Can I use a valve spring tool to simply reinsert the rockers in their original position and start the car. With the timing marks all aligned will it be fine to just install rockers without any further worries. Please see pics and advise.
c
c
