How do you read this? Obviously in Celsius. What’s the correct range for operating? I just had my thermostat replaced, radiator flushed, belts checked, and it’s running cooler.
Thanks dankly1. Good suggestion to flush the system first. I'll do that and check the thermostat.That sounds like a slow or late opening thermostat to me. I would recommend starting with replacing the thermostat. A citrus flush of the system would also be a good idea...that is a maintenance item that often gets neglected.
Thanks MBGraham. Thrust me, I have been reading this manual like a book in the last weeks.This link explains how the coolant system works.
Could you post a copy of that service bulletin? It would be interesting to read just what it says. Was it for a 107 or your 300SL?The initial rise in reported temperature is quite usual (mine has been doing it for 30+ years) and there is even a service bulletin which recommends drilling a small hole in the rim of the thermostat to allow a small flow of coolant even when the thermostat is fully closed so as to lessen the rise and to silence demanding customers.
My car is CLK 500. In the cool day, it is about 80 C. For summer time with air-con on, it went up to 100 C. The reading on your gage is about 90 C and it is normal.That looks pretty normal. Hot days in heavy traffic and it will go up
Very obviously the next line is 100. The lines are at 40, 60, 80 and 100.do we know what number the next line is?
I have an ML 350 W163. Thats where my gauge sits also, engine has less than 60k miles ,runs perfectlyHow do you read this? Obviously in Celsius. What’s the correct range for operating? I just had my thermostat replaced, radiator flushed, belts checked, and it’s running cooler.
This is the link to a good Citrus Flush tutorial from Diesel Giant. Even has lots of cool picturesThanks dankly1. Good suggestion to flush the system first. I'll do that and check the thermostat.![]()
Best explanation I have see so I re-posted it from another web siteHow do you read this? Obviously in Celsius. What’s the correct range for operating? I just had my thermostat replaced, radiator flushed, belts checked, and it’s running cooler.
