Hey guys. I just wanted to start a part number thread because Club202 had one and there isn’t one here on Benzworld. I personally drive a C43 and so many of these part numbers may not apply to your car, but most of them are for the W202 chassis. I took some of these part numbers from Club202 so props to them also.
Facelifted Keys
2117663606
2037665006
Front Wheel Bearing Repair Kit
2103300051
Tie-Rod
2024600505
C43 Engine Mounts
2022402917 (x2)
C43 Intake Air Filter
WA1040940104 (x2)
C43 Brake Caliper Repair Kit
WA2104210118
All Weather Mats
Q6680344
C43 Engine Oil Dip Stick
1130100472
W202 Shifter Shutter (the screen inside the shifter)
1292670026
C43 OEM Oil Filter
0001802609
W202 Cubby (replaces cassette holder)
2026830091
C43 Floor Mats
Q6680393
W202 Trunk Luggage Net
67650010
W202 Door Panel Clips
0039884178
W202 Roof Moulding Clips
2016980660
C43 Engine Cover
A1130100567
W202 Windshield with Rainsensor
2026700701
C43 Brake Dust Plate
Front Right
2104212520
Front Left
2104212420
Hood Badge (Star)
2108800186
W202 Euro Trunk Lid
Trunk Lid
202 750 07 75
Handle
202 758 01 02
Trunk Star
202 758 02 58
Rubber Grommets for Trunk Star
163 997 06 81 (x3)
Mobil 1 Decal (under the hood)
2205843038
C43 Brake Pads
0034202120
AMG Valve Stems
BQ 6408127
C43 Brake Rotor
Front Left
2104211812
Front Right
2104211912
Brake Pad Paste
0019899451
Automatic Transmission Fluid
001989210310
Covers for Door Locks (from ML)
A 2107660056
Avant-Garde grill
B6 688 0127
A2108880123 [w210] (Requires cutting)
Completely red Euro Taillight Lens:
B66809890
SLK Sport Pedals for W202
Accelerator pedal
A1703000004
Brake pedal
A1702900282
A2034300084
White background for heater regulators (of the SLK)
A1708172520
Turn signal left
A2028261143
Turn signal right
A2028261243
Shelf Instead of Ashtrays:
Shelf largely
A2026800591
Plug socket
A2108200951
Parts in 744 silver WITHOUT chrome:
A2087600070 9744 - door handle in front
A2107601270 9744 - door handle in the back
A2087600977 9744 - end piece in front left with IR and lock
A2087600577 9744 - end piece in front right with IR without lock
A2107660356 9744 - end piece in the back
Steel Carter Plate
2025240001
Mounting Support
202 520 0133
Bolt for mounting steel plate & support
2019900204 (x6)
Mutter for mounting steel plate & support (x6)
2019900991
Fixation Material Isolation
1249870740(x2)
2019880381(x4)
2019880481(x4)
Stock Lower Engine Cover
2025241330
Screws
2019900536 (x4)
Lock clips
0019949845 (x4)
Universal 722.6 transmissions Dip Stick
140589152100
1409910055 (Red locking clip that breaks when you open the cap)
W202 CD Changer Cartridge
A0028206289 (99+)
Warning Triangle for Trunk
2038900197
202 890 00 14 (Mounting Bracket)
C36 Front Camber Bolt
A2023300118
Auto Dim Rear View Mirror US Spec Driver (left side) Sun Visor with Home Link
2108100310
CLK Door Lock Pins
A1237660022
Oil Wrench (nice for oil changes)
103589020900
C36 Spark Plug Cover
HWA 10 41 50 0375
W202 Sunshade
Q6670001
AMG Window Sticker
1295840838
Transmission Pan Magnet
A2202710098
W204 Flat Badge
A204 8170616
Lenses
2028205766 LH HID/Xenon
2028205866 RH HID/Xenon
2028206366 LH Halogen
2028206466 RH Halogen
1708260990 LH C43 Fog
1708261090 RH C43 Fog
Seal, Joint (rubber) for Headlamp Assembly
2028261180 LH
2028261280 RH
Covering for fogs C43
2026982730 LH
2026982830 RH
Transmission Cover [includes O-ring]
0229972248 (C43)
1402700091
Wheel Center Cap
2014000425
Facelifted Keys
2117663606
2037665006
2103300051
Tie-Rod
2024600505
C43 Engine Mounts
2022402917 (x2)
WA1040940104 (x2)
WA2104210118
All Weather Mats
Q6680344
1130100472
1292670026
C43 OEM Oil Filter
0001802609
2026830091
C43 Floor Mats
Q6680393
67650010
0039884178
2016980660
C43 Engine Cover
A1130100567
2026700701
Front Right
2104212520
Front Left
2104212420
Hood Badge (Star)
2108800186
W202 Euro Trunk Lid
Trunk Lid
202 750 07 75
Handle
202 758 01 02
Trunk Star
202 758 02 58
163 997 06 81 (x3)
2205843038
C43 Brake Pads
0034202120
AMG Valve Stems
BQ 6408127
C43 Brake Rotor
Front Left
2104211812
Front Right
2104211912
Brake Pad Paste
0019899451
001989210310
A 2107660056
Avant-Garde grill
B6 688 0127
B66809890
Accelerator pedal
A1703000004
Brake pedal
A1702900282
A2034300084
A1708172520
Turn signal left
A2028261143
Turn signal right
A2028261243
Shelf largely
A2026800591
Plug socket
A2108200951
Steel Carter Plate
2025240001
Mounting Support
202 520 0133
2019900204 (x6)
2019900991
1249870740(x2)
2019880381(x4)
2019880481(x4)
2025241330
Screws
2019900536 (x4)
Lock clips
0019949845 (x4)
140589152100
A0028206289 (99+)
2038900197
A2023300118
2108100310
CLK Door Lock Pins
A1237660022
103589020900
HWA 10 41 50 0375
W202 Sunshade
Q6670001
AMG Window Sticker
1295840838
A2202710098
W204 Flat Badge
A204 8170616
Lenses
2028261180 LH
2028261280 RH
2026982730 LH
2026982830 RH
0229972248 (C43)
1402700091
Wheel Center Cap
2014000425
