Should I use Lucas Stop Slip Transmission Fluid?
5.2K views 9 replies 5 participants last post by  mercedesowner230
I have a 98 Mercedes SLK230 and my transmission is going out. It isn't horrible but it is getting worse, It tends to slip and catch in between second and third gear. I was wondering if I should use a bottle of this stuff in it temporary, and was also wondering what the ups and downs could be. I read on some peoples reviews that it works great and others say it doesn't work at all, and I was reading something about that if you put it in that you would need a engine overhaul, is that true?
Please let me know.
Thanks.
#3 ·
What is the mileage and has the transmission fluid and filter been changed at all?
#7 ·
With metal flakes in there, this addative will be of little use, you need a transmission rebuilt.
#9 ·
I actually thought the same but, as it stands now the transmission can be rebuilt, however if he puts this addative in and it destroys the clutch packs then a rebuild may be out of the question and he will need another tranny instead.
