Rear end squeaks
1 reading
7.8K views 23 replies 6 participants last post by  swampy320
I have a 1999 e320 with the standard suspension. I’ve replaced the anti sway bar bushings and control arms except the large lower control arm and my car is still squeaking. I thought i fixed it with the control arms but after a quick test drive it started again.
I’ve narrowed the issue down to the springs, the shocks and the lower control arm bushing unless anyone has other ideas. The shocks appear to be ok so I’ve been dreading dealing with the lower control arm bushing. Thoughts?
#3 ·
Paulcomi,
I have the tool that you would need to replace the rear spindle/knuckle bushing. I meant to put it up for sale, but haven't done so yet. See
https://www.benzworld.org/forums/w210-e-class/2892929-squeeking-rear-wheel.html#post16668633 Below are two pictures:
Let me know if you might be interested (and if you are, where you are located).
Before you do this, however, you might want to check how the rubber boots on the bushings look like. They become visible when you take the plastic cover off the lower control arm. I once chased a squeak in the rear end which I eventually found to be caused by a brake line rubbing against a bracket. A bit of silicone fixed the problem. (The rear knuckle bushings were still due for replacement, though, the boots on one of them were already torn.)
#6 ·
I am with tech4tech. My experience is with my W124, but it was those bushings. My friend the master mechanic fashioned a tool involving a bolt, pipe to be used with an impact wrench. They are not easy to R & R.
A trick he taught me in locating noises - with the car on a ramp, have a friend slowly push the car - run your fingers along bushings and parts you suspect. With a squeak you should feel just a bit of vibration on your fingertips.
#23 ·
It's been a good 15 years since I did this and I can't tell you with certainty. But I do remember that the photos I provided were the bushings, and my (late) friend fashioned a tool - and needed an impact wrench - to drive out the old ones. They get rust on the outside and it is the rust that causes the squeak. My 124 sounded like an old covered wagon it was so bad.
#14 ·
Hi Paulcomi,
Are you asking me about the tool? Where are you located? The cheapest domestic shipping option in the US (USPS medium flat rate box, I think) is around $15 one-way (i.e. shipping it twice would cost $30). What would a fair rental fee be -- $20? If you prefer not to buy it (you could resell it yourself afterwards), then we could certainly do that, but I would ask you to pay the $75 nonetheless as a deposit and would then reimburse you the difference (i.e. $40) when I receive it back. Let me know what you decide.
That aside, I would definitely try to make sure you know what you need to replace before ordering parts. I doubt your rear lower control arms need to be replaced--I don't think the very simply and sturdy inner bushing is prone to failure.
#20 ·
I am pretty certain I have read somewhere (likely on this forum) that that can be done without risk, although it would be better if somebody more knowledgeable could confirm this.
If you are interested in the knuckle bushing tool, perhaps you could send me a "private message" (left click on my user name in the thread) and we could work out the details.
#21 ·
Update: thanks to someone in this thread who sold me the bushing press tool, I was able to remove and replace the bushing on the wheel knuckle and that solved the annoying squeaking. I was happily surprised to find that it was not necessary to remove the coil spring in order to replace this bushing. With the car on a jack stand and a floor jack under the lower control arm, the bolt at the bottom of the knuckle is removed and the knuckle is pulled out to separate the lower control arm. The tool is necessary to press the bushing out and also to drive the new one back in.
