Thanks to the help of many on this forum, I've almost been able to solve my central lock problem. Almost.
Here's the scenario:
* Remote central lock isn't working on the doors. I hear the PSE run for about 15-20 seconds, then it shuts off.
* Same thing when I try the switch on dashboard.
* The trunk DOES open with remote and manually.
I've pulled the PSE pump and checked for system leaks, one yellow line at a time. I can 'blow' into the line for the driver door lock, and lock button raises. When I 'suck' on the line, the button lowers. Same thing for the passenger door. Fuel lid works this way also.
Using the same procedure, I really can't tell what's going on with the trunk functions. Nothing really happens here; I don't detect a leak, but can't hear anything 'move' or engage. Yet the trunk lock seems to work as it should.
I pulled the cover off of the PSE pump to inspect the motor and other internal hose connections, etc. Everything looks good and tight here. When I put it all back together, central lock works perfectly for about 5 or 6 times then fails. I've done the entire above procedure twice with the same result both times.
What am I missing here? Is my problem somewhere between PSE pump and trunk mechanisms, or in the pump itself?
Thanks,
Mark
Thanks,
Mark
