When I connect my Autel device, no error codes appear.
I have noticed the following:
When I start the engine, I cannot properly select gears with the shift lever – it always stays on “D”. In positions “P” and “N” the engine revs up to 3000–4000 rpm. In the driving gears, however, it only stays at 800–900 rpm.
I hope this description helps you better understand my problem.
“Mercedes C-Class 2005 – Transmission 722.6”
- In position “P” it correctly shows “P”.
- In position “R” it also shows “P”.
- In position “N” it shows “N”.
- In position “D” it shows “N”.
