81 - 100 of 137 Posts
Hi Guys,
My warranty ran out recently and i serviced my car myself. I am an engineer and have worked on cars for years so i have a bit of experience in building engines etc.
Here is the problem:
I unscrewed the oil filter cartridge housing and removed the filter, what was strange to me, was the fact that i didnt find a place for the o-rings in the packet. After drying the rest of the oil in the housing, i saw that the bit with two smaller o-rinds is still stuck at the bottom. I also noticed that whoever has worked on the car at MB during its maintenance plan has broken one of the legs of that part trying to get it out. It appears that the end bit with small rings clips into the rest of filter "shaft".
So my question is: Has anyone come across this problem? Could someone post some pics with the end bit removed so i can see its geometry to come up with the best way to pull it out without breaking anymore legs.
Thanks in advance:)
Newbie here. Fantastic post, thank you.
New question:
How do I change the oil on a MB 2002 year model C220 CDI?
Can I suck the oil out with an extractor through the oil input as I do not see or know of a dipstick hole on this diesel engine?
Lastly, what oil do I use?
Thanks for a great forum and the willingness to help!
Thanks in advance:)
Does this pic help you?
Great thread!!! My sister-in-law takes her car to Sears and they said they could service mine. Not so true. I asked them if they could reset light and they had no clue and actually wanted me to print out your instructions and bring them to them. Needless to say my brother is changing my oil. Thanks for great info!!!
Will this work on an 01' C320?
Reducing Engine Oil
Seems I followed the instructions to the letter, but for some wild reason the car thinks I overfilled the oil. On first check after reinstalling the covers under the car, the oil level said "ok". Drove the car for 2 miles to test and now it states "reduce engine oil". Anybody got a quick fix, or without have the extractor, do I just have to yank the drain plug again and jam it back in midstream? Please any assistance will be greatly appreciated.
Dazed and Confused..
Kanesr228
A few comments:
1. What engine do you have, and how much oil did you put in?
2. On my CLK I can read the precise oil level at the cluster (in litres, when warm & level) in addition to the 'OK' message. Not sure about your model.
3. I would try to extract any surplus oil by sucking up via the dip stick tube. Thin plastic tubing would do the trick.
My 2002 C230 Kompressor Sport Coupe appears different... The oil filter is towards the front, under the front "snap on" cover. The oil dip-stick (I think someone added this?) is near the front of the engine near the oil filter. Are you sure the model discussed in this article is supercharged (der kompressor, ja!)?
Have you considered sucking the oil out of the dip stick tube like the dealer's do it. Seems less messy and quicker. This is what some of the guys use on the SLK forum - Pela 650 Oil Extractor at
I almost bought the Pela, but did not like the capacity (since the car is 7 to 8 quarts).
Then I was browsing the Northen Tools catalog, and found this 8-quart model (for less than the Pela):
LiquiVac Oil Extractor — 2 Gallon | Oil Extractors | Northern Tool + Equipment
Only down side is it's not as easy to see the oil level in the extractor, but empty is empty, right?
