Gear position indicator..
1 reading
1.6K views 9 replies 5 participants last post by  roy560
Dear all,
I remember reading somewhere here (not sure if it was a link to another forum/thread) about someone doing a modification/retrofitting a fiber optic cable with a OEM bracket from a W124 so that the gear that we have selected (PRDN21) will glow brighter on the gear position panel around our shift knob area.
I have spent hours searching, probably i am not typing the keywords right.
So if anyone remembers the link, please direct it to me ya.
Thanks in advance.
#7 ·
Hmm can't quite remember, sorry. Think there's one at the front, its very easy to see once you have the wood piece off though.
Once dissembled you could use metal polish on the clear plastic window, it brings it up like new.
Cleaning the bits here makes it look much better.
#8 · (Edited)
BE CAREFUL!!! I just did this. Look very closely at the front of the black shifter "box" once the wood is removed. You will see 2 small black plastic square buttons. Pry these forward with a small pocket screwdriver and remove, THEN pry up on the front 2 sides of the box. These little pins (buttons) keep the clips from releasing when you pry up. The shifter lens and PRNDL simply lie there. You can lift them up enough to polish them. You will find dust, toothpicks, dimes and maybe illegal drugs in there under the wood!
