Hi Guys
Im currently helping a forum member solve an issue with his knock sensors. We took it to a shop and they took the manifold off to see what the problem was and it turns out that a mouse had made the M120 his home. There was saw dust, chicken bones and it seems he chewed off 3 out 4 knock sensor wires clean and the insulation on one of the rpm sensors. The mechanic also noted that the boot on the passenger side EGR valve was ripped off.
I wanted to ask, any negative affects such as check engine light if we remove all the EGR related stuff and simply put a block off plate?
