My 560SEL with 212k miles has started blowing smoke on/off; my mechanic says the valve seals are shot and it's time for a top end rebuild. Compression is about 150lbs all around except for 125lbs at cylinders 5 and 6. Leak-down is 10%.
Since I'm not going to rebuild the engine myself, this is going to be $$$. So I want to get it right. Anything I should ask my mechanic? Anything I should get done while the engine is out? Timing chain? Rear main seal? A/C evap/condenser (which has been broken for years)?
Also, please let me know if you have any shop recommendations for the San Francisco area. My mechanic has a shop they work with (Star Machine) but I'm open to alternatives if you can vouch for their quality.
I'm thinking of this like open-heart surgery for my car. I want to use the best surgeon I can find...
Thanks, all.
Thanks, all.
