Hi all,
I usually post something when I run into issues and after I spend a good couple of weekends playing with my 350SL.
I recently removed the center console to fix a few cracks and repainted it. After re-installing it, the dashboard lights, the clock light and the heating control lights won't switch on... All the fuses are ok and it does not seem to be a grounding issue as if I apply the 12V directly from battery to the clock light, all the lights switch on.
This makes sense since according to the wiring diagram all these lights seems to be on the same circuit.
Most probably there is a loose contact between the light switch and the lead that goes to the dashboard, which is odd because I didn't touch that area.
Now to make this post a bit more interesting I can also tell you that a couple of days ago I hit a hole on the road and magically the lights went on until I stop parked and restarted the car...
Do you think I will have to remove the instrument panel and the light switch to fix this issue?
Would make sense to run a cable from the light of the shift case (this works as expected and turns on upon when turning the lights on) to the lights of the heater control (I know this might be a kind of a hack, but I am not sure how to remove the light switch).
Any idea, comments, insults and suggestions are really welcome.
Thank you
Thank you
