I've had the problem, so have dozens more.
correct operation:-
turn ignition on, glowplug light comes on and goes out within 2 seconds...... ok
On ALL the time:-
with NO interuptions i.e ignition on, light comes on permanently....... 2 or more glowplugs, or relay (next to radiator) faulty..... it doesn't do anything apart from correct operation if only ONE glowplug is faulty........ commonly the thick red power lead to the relay has snapped off from its mounting screw
ON briefly:-
(goes out within 2 seconds) then comes on AGAIN and STAYS on...... the immobiliser has operated.... normally a door has been opened or the ignition tried with the wrong key...... it is ONLY clearble with star diagnosis as it tells you someone tried to steal it (the official reason).......
A weird trick..... I found out by accident.... unplug the cables from the air sensor in the middle of the pipe that goes across the top of the engine (about 3inch diameter hard pipe).... drive it.... it should be in limp mode.... you need a few miles at enough revs for the limp mode to operate....... reconnect everything........... this often cures the "fault" because of a "backdoor" in the ecu programming......... it also works on a few other warnings.
malcolm
correct operation:-
On ALL the time:-
ON briefly:-
malcolm
