1 - 7 of 7 Posts
Six_wheeler
1982 Peugeot 504 Familiale station wagon; 1991 Toyota Cressida XL station wagon
Hello people...
I guess the title pretty much says it all. Now, I've managed to obtain four part numbers for the harness, but I just can't verify which one will match what I have. I called a few dealers in LA and Seattle, but none of them could be of much help other than to give me the same four numbers, since my car is out of Japan, so the VIN won't be of much use.
Here are the numbers I got:
124 440 56 32
124 440 29 33
124 440 52 32
124 440 27 33
Now there should have been a tag on the old harness stating the number, but it's gone now. What information (even a visual description of... well, anything) do you guys need to help me figure out the exact same match for my car?
Guys, I really need your help on this one.
(And yes, I did try the search function.)
Discussion starter · #3 ·
Yup, it's a 1994 E320. My engine number is this:
104992 12 062618
To update, I called a few more dealers in Seattle and New York, and by checking the VIN, at least four of them confirmed that 124 440 52 32 is the one, but I need to be absolutely positive. So, if I post pictures of the connectors and what not, would that help you to confirm?
Thanks.
Discussion starter · #5 ·
Thanks! I'll forward this to my cousin in Germany.
Discussion starter · #7 ·
Thanks. I located one at the dealer's main branch in Jeddah with that particular part number (5200 riyals after the discount, or almost $1,400!!!). I'm going to check that out and see if it's the same as the bad one on my car before I proceed any further.
1 - 7 of 7 Posts
